Or better yet that clean edge around that piston is caused by the unburned fuel leaving that cylinder with the compression. It needs to come out…….I’ll bet it looks like that piston pic Nige posted earlier.2nd piston looks like it is hitting the top of the head check rod and wrist pin also looks like it has a lot of burnt oil built up on it
That's called a valve relieve or eyebrow pretty normal .Also is it just me or does that piston look strange up near the top?
Red arrow in picture below:
Been a few years since I worked on a D333 or 3306 but don't recall a piston that looked like that! Maybe a little cutting from the carbon like the black streaks but there apears to be a large amount of material missing on that side.
That's the problem with only seeing a picture and not having it in hand! From that angle I was thinking the top of the piston was eroded away.That's called a valve relieve or eyebrow pretty normal .
Bob
Are the valves and valve guides for that cylinder intact.? No small pieces missing.?I cleaned the piston. It's new. it has a dent, I think something got in from the side of the air filter.
I would say that is sand colour is normal and indicates good combustion. Black deposits would indicate poor combustion. Because your problem is recent there has not been the opportunity for black soot deposits to accumulate.When I clean the valves I expected a lot of coal. Instead, with the drill, a rust color came out.
The residue I removed looked like sand-colored flour.
