per step 1 900psi and then drops like a stone
So that should be approximately the acumulator precharge pressure, which is around 950psi depending on ambient temperature. Double confirmation that the accumulators do not appear to be the root cause of the problem.
I think that somehow you have to make sure that the pressure you measured in the system from the test point is actually reaching the brake valve. This might involve making some sort of temporary connection where one or other of the lines from the accumulators supply the brake valve. I can't see any reason why you should not be getting full system pressure there but it's worth a check.
Please ensure that nothing is messed up in the floor linkage (the left pedal is connected by a link to the right pedal). If it's all good then it seems as though you are going to have to go into the brake valve. See attached which is how it operates. Not the easiest thing in the world to get at unfortunately.
And I've saved the worst part for last - there are no service repair parts for it so it's a new replacement valve or nothing. It seems as though this is typical because I looked at a couple of other models that use a similar design of valve (but different Part Numbers) and they are not serviceable either. The Part Number for the valve illustrated below is 215-3687.
