mobile-tech
working on a 938g series 2 loader serial crd01895 , brakes work but at the bottom of the pedals also seems like neutralizer isnt engaging , any inforamtion i can get on this system would be greatly apeciated
Your S/N is missing a digit. There should be five numbers at the end after "CRD", not four.0938gkcrd0185 is the full number off id plate
1. Start the engine and let it run for a couple of minutes to allow the accumulators to fully charge.i have not checked accumulators , what is the procedure for that ?
That's within specification. According to the O&M Manual it should take "at least 5 pumps" for the light to come on.i have 7 pumps before the light comes on
It looks like a brake overhaul is looming large on your immediate horizon then........in 3rd it stats to push threw service brakes at 1500 rpm
If oil does not smell burned and with only 3550 hours on the machine the probability is that the brakes are OK. TBH 3550 hours changes the picture totally. I agree you would not expect the brakes to be worn out at those hours.oil looks good , these axles dont have coolers on them, single hose to each axle , oil smells ok
