crane operator
I think that's what the trans. is Rzucker, I'll look at it tomorrow.
I'm also betting it has a solenoid valve on the left side just above the shifter arm. External/Manual convertor lockup. The military used lockup to run winches without having to rev the engine up, It also works as a hold back on steep grades.I think that's what the trans. is Rzucker, I'll look at it tomorrow.
I like the idea of a 3000 series a lot better than the 6xx but if the deal is good, you should probably take it. The 3000 series is still a current product more or less while the 6xx is getting pretty old.
I'm told he shift points are adjustable by rotating a ramp thingy behind each valve body spring, but they may be just fine for the engine you have depending on RPM.
I just remember all the Allisons I used to drive, when we'd get a new truck the transmission would be very well set up. Sometimes the shift logic would give you a weird feeling being used to a car but if you thought about it, you could see the logic, why they held it in lower gears longer, kind of let the engine rev out when at WOT, or not immediately upshifitng on throttle release, lots of little nuances that made it operate more effectively.
Then we got another new truck, and the Allison programming stunk. It was something like a 2000 RPM program on a 2200 RPM engine and it was bogging all the time. Eventually we got an Allison engineering/service guy out there with a laptop and he re-did pretty much everything and after that it was great. Until the ECM had a problem and when they did the repair the shop changed it to "garbage truck" program where every time you lifted the throttle with the Jake switch on it went for 2nd gear. [I wanted to coast down this hill not come to a complete stop!] I left that job before we resolved the issue, the engineering guy was always busy and came from a long way off.
So like everything, it seems in these new days, the hardware is pretty good but the service people don't know what they are working with any more, and the one smart guy is always too busy to get to you.
Anyway I just told that story because just because it is an 8.3, the rev ranges might be a little different and the shift speeds might need adjustment to make it operate the way it should.
You are just the guy I need to talk to. I have put the Allison on ebay and decided to also go with a roadranger. Biggest holdup is I don't know anything about bellhousing fit up and such. I found a Roadranger guru at Inland Truck Parts in Springfield but he's on vacation this week, I'm sure he can answer any Roadranger questions but my concern is what bellhousing to look for that will work on the 8.3 and fit a 10 or 13 speed? Also will my starter still work? Chances are, when I find a transmission it may even have the correct bellhousing, clutch, etc.
When I mentioned Mechanical, I was referring to the 600 series Allison that Crane OP has. Putting a RoadRanger in combination with the engine swap may be a good sized headache. But hey... Anything is possible.
I like the Allison mechanical idea because there is no fixed linkage geometry to figure out by trial and error.
