New here looking for some help. I have a 303CR, serial DMA-05055, which will not start with the key. I can jump the solenoid and the machine will run. However, I do not have any hydraulics accept for the blade. I believe the issue is in the safety switch circuit. Machine will shut off with key. I have tested one relay, 250-2048, and found it to be functioning as it should. This relay is the only one I can hear/feel actuating when the safety lever is lower/raised. I am unable to determine if there is another relay in the circuit. Any guidance will be greatly appreciated!
