Mlgibson
My 299D3 just went down on me. Started with no aux hyd code 2204-3. Then CAN Data Link=Pre-NOx Sensor. Now E361-3, Gauges never showed temps were warm or hot? Where do I start, machine has 800 hrs.
A Serial Number would be a good first step, closely followed by the exact Diagnostic Codes/Events that showed up. From your OP I assume you have the LCD Advanced Display installed which does make things somewhat easier.Where do I start
This is the first one that should concern you right now, and is the reason the machine went into limp mode. I am not sure even if after correcting the problem the machine will go out of limp mode without dealer intervention. Hopefully one of our Tier 4 experts can comment.I had noticed a yellow code popped up, 523617 ACU (CAN Data-PreNOx Sensor Data Erratic, Intermittent or incorrect)
Were you aware that the aftertreatment system on your machine is warrantied for 5 years from date of purchase.? You ought to be able to get this sorted by a dealer at no cost to you. It is worth contacting them and asking at least.
From the information I have the emissions system warranty is not limited to the original owner and remains valid for 5 years from the original sale date of the machine.Would this warranty only apply to the original owner?
