Hi, where did you buy letter "e" oring at from your picture? Thank you JohnA very common issue is to forget the O-ring between the filter and the water bowl. Letter "E". This will give you the same symptoms that you describe.
View attachment 182400 View attachment 182401
Check your hydraulic lockout switch. If the switch is flipped the machine will still travel but lift arms do not work. If it has an enclosed cab, make sure the magnet in the door hinge is still there.Hello guys my 262c skid steer arms wouldn't raise or low but the machine still drives and the yellow light stays on can i get some help please
