Hi guys,
The machine is a Case CX130B(BAC130K5N8SAD1114) with a 4JJ1X Isuzu engine.
It's starting, running briefly and then shutting down again at low idle but runs at high idle so when no functions are used it shuts down. I've been to it before when it was only intermittent and found really dirty fuel and a rubber band in the fuel filter. It also had an active voltage above normal fault code(!0193) for the common rail pressure sensor when the machine shuts down. I recreated the fault by wriggling the wires to the pressure sensor and the machine would shut down.
I couldn't change the filter at the time, but I told him to change it ASAP and he said he did. I re-crimped a female pin on the pressure sensor connector and the code went away but in needs a whole new connector and I can't find where to buy them.
This is the first case machine and isuzu engine I've worked on and I don't know much about either. I don't have the technician software.
Here are my questions:
1.If I get there and the code is no longer active, how likely is it that the pump and/or injectors have failed from dirt getting through the old filter? and what tests can I do to confirm they have failed?
2. Where can I buy the connectors in the attached picture in Australia. Case will only sell the full harness.
Any help would be appreciated
Thanks
Thanks
