Case 580CK tachometer drive puller for 188D diesel
Festeraxp
South Central Pennsylvania
I walk the toughest blocks in State
The tags where the serial number was are gone. All I have is the one on the engine. Then there was one below the seat but it’s all faded away.
Festeraxp
It sucks because it would be a lot easier to find stuff out about it. It was my paps. I’m assuming early 70’s or late 60’s. Maybe earlier.
Tinkerer
It appears to be a 580CK. The air cleaner is different on the 580 series C.
So, someone has converted it to a alternator. I am guessing it is wired incorrectly or the alternator is defective.
Is it a GM alternator ? I have done those conversions myself and the idiot light works correctly.
Festeraxp
The idiot light worked correctly before too but now after I rewired it, it stays on. So obviously I did something wrong.
Tinkerer
Can you post a photo to the back of the alternator. It appears the wiring is incorrect from what little I can see. There should be a plastic plug with two wires plugged onto two spade connectors at the top of the alternator.
Festeraxp
I see the spot where the tab should be plugged in but I do not have one. Any suggestions. What wires are supposed to run to it?
Tinkerer
That plug can be purchased at any auto parts store. I don't know how your red light is wired but it needs to be wired like in the photo I am posting.
upload_2019-2-3_17-23-22-jpeg.192261
