Coytee
I'm busy working today (though from home) but am still busy... so haven't read everything.
Disclaimer: Presuming I'm seeing it correctly and interpreting your process correctly, then "me personally" gets nervous with the hydraulic setup. I personally would be very nervous that I'd bend, ever so slightly, one of those ears that hold the pin and cause a greater issue. For all I know, they may be strong enough to withstand that pressure....and that's my point, I don't know therefore I get nervous as I see it as a potential problem.
I'd probably be measuring for thickness to see if I could cut with a sawzall, grinder.... the upper and lower pin so the knuckle can come out. Now there's no way to bend the ears that hold it and you can man handle it.
One of my bearings was worn enough that I had plenty of room to get a cutoff wheel in there (verses a sawzall) and got it cut.
Notice I don't say anything about flames.....that's because I don't know anything about them and if they'd work or damage something else (note that the cutoff wheel or sawzall can damage something else)
