Does anyone know if I can swap my 1840's hydraulic pump for a 40XT or even a 60XT or 75XT hydraulic pump? They all have a 7/8" 13 spline shaft. The 1840 puts out 15 gpm, the 40XT flows 19 gpm, and the 60/75XT pumps out 21 gpm. The biggest concern I have is the increase in relief pressure from 2300 psi to 3000 psi. My current pump works fine, EXCEPTwhen running an open front brush cutter, which is one of my main reasons for wanting a skid steer. The lack of flow, and moreover the low relief pressure cause it to stall out WAY too soon. The motor doesn't know there is even a load, and the hydraulics go into relief. I have the same Cummins 4b motor that the donor loaders have, so horsepower is not an issue. My main concern is overpressurizing my hydraulic system. I gather that my drive system is seperate, and shouldn`t be affected by such a swap. Anybody have experience with this?
