I would run the vin # and find out the drum number and take your time looking for some drums. It probably is using a 5" shoe on a 16K axle. Either way I would do some shopping. IMO
I'm not saying I haul this but it is legal with a heavy haul permit as I read the laws. I do have a triple axle air ride pintle hitch trailer I pull.
I actually do a lot of farm work close to my house and will drive the loader a couple miles down the shoulder of the highway and down gravel roads. Poor people have poor ways!!
I'm looking to buy a used tandem dump, so after reading this thread I spent time reading up on class 8 trucks. Peterbilt, Freightliner, Kenworth, International. I found out a few useful things.
1) To avoid emissions malfunctions and downtime, avoid built-after-January 1, 2007 EPA compliant engines.
2) Some guys like IHC for entry-level trucks, starter trucks, relatively reliable. After reading up on Navistar, I'd rather save up some more shekels and buy another brand. Navistar is a train wreck. I've worked at big companies, seen this kind of hubris and denial, but usually it only lasts a fiscal year until the board installs new execs. Navistar sued partners left and right, even sued Cummins, and denied reality for a decade. Cat, to their credit, bowed out honorably instead of do SCR. https://infogalactic.com/info/Navistar_International
3) Peterbilt never ran to Mexico like Freightliner did, putting American workers out of their jobs. Petes are still built in Texas, so I think I'll buy a 2006 or earlier, SFFA tandem. Lots of Peterbilts to choose from.
Something else that popped up that has confused me while the truck had a small oil leak on the drivers side before, they said it leaked really bad in one of their bays, then outside when I came for it there was probably a 16" circle of oil under it, they said it was only from it but no idea. They said they believed it was coming from behind pump on drivers side. So I have watched it closely since but it's only leaking a tiny bit here and there, oil level hasn't budged. Probably 1 hour of idling and 2 hours of driving since. I know the truck has sat a lot the last few years, but if a bad oil leak popped up it make no sense it would go away again?
That leak behind the injection pump may be bad o-rings between the pump and block. It can come and go depending on the temperature of the engine. if it is leaking at that point, the pump will have to come off the engine to repair it. (NOT cheap). If those guys charge that kind of money and don't fix the problems.... You are getting HOSED. Find another shop.
