pumkinhead
Which AIS location, they should have no problem
65809 Gratiot Ave, New Haven, MI 48050Which AIS location, they should have no problem
Happy times! Glad you got it cracked loose!
The black pieces you pointed out are often called bearings or guides. They are used to keep the piston square in the bore. They are oftentimes not available separate from the piston itself on NH machines. They do not seal so if they got a little roughed up, no big deal. Make sure there isn't any metal imbedded in them, they are smooth, and clean, and reuse them.
If you are going back to have the piston bolt reinstalled, carefully wrap the piston to protect it. It is not ok if the seal in the middle gets banged up at all.
Success! Cylinder is back on and not leaking - so far
One last question:
What is the secret for installing these:
What a total PIA they are. I tried pretty much all the tricks I have and ran out of daylight.
Thank you all again.
R
Those are easy!On either side of the base of the cylinder rod base ...
View attachment 291345 View attachment 291346
Yup then when get it about two thirds on it goes flying and you spend 10 minutes trying to find it. LOLThose are easy!
Start one side in the grove, take a flat tip screwdriver and work yourself around until the thing pops itself all the way on.
Funny you should say that...I now have my metal detector stationed inside the The Beast...Yup then when get it about two thirds on it goes flying and you spend 10 minutes trying to find it. LOL
Or worse yet, It hits you in the eye and you need to go to the hospital Dumb design...It does work once they are in tho.Yup then when get it about two thirds on it goes flying and you spend 10 minutes trying to find it.
