Paul Coates
I have a bobcat t300, has several hydraulic issues all seem to be coming from the same main problem. Error codes that sometimes come up on the display are extreme low charge pressure
Issues:
Issues with the auxiliary hydraulics (not working at all)
loader will only lift (wont come back down)
bucket will only dump (will not raise back up)
drive works but seems like the brakes are dragging a little
Something I also found very weird was that if I am running the machine and I pull one stick slightly back and the other slightly forward, (not even enough to make the machine move)
the loader operates completely like its supposed to with full hydraulic power - Hopefully somebody could help alittle on this
Issues:
