Bobcat 773G fuel pickup: DrJim is back on HEF!
Willie, you knew it was bound to happen. My computer guru was whining about a concrete slab he couldn't move with his JD 1025 subcompact tractor/loader. He did the smart thing--he asked his dentist--on Sunday. Dug the Contrail out of the barn, loaded up the skid-steer and went to show off. It turned out the slab had a 5 ft long piece of 8" casing attached, stuck straight down, apparently as a base for some kind of tower or pole. The B'cat lifted it up and over. Piece of cake. Dug up some stumps, too.
But traversing the back lot, off camber maybe 30 degrees to the operator's left. . . the Kubota motor sputtered twice and died. Hmmm. Drained the fuel filter--no water. Set out to bleed the filter/fuel line, and it sounded like the primer bulb was sucking air. No sign of any fuel. Of course, the fuel gauge showed 7/8 full. What the . . .? I was baffled. . . until I remembered HEF and my friend Willie. My memory was jogged--I remembered seeing something about darn Bobcat fuel pickups.
My friend had a 5 gal can of diesel for the JD 1025, so we dumped it in. Didn't take but maybe 2 1/2 gallons to fill up into the filler neck. Voila! The primer bulb was now pumping liquid. Bled the air. . . and it fired right up.
So, what happens on the 773? Does the entire pickup just fall off of the elbow fitting? Now that we've packed it with fuel, will the fuel come burping out of the grommet fitting when I pull the fitting out? (If I can get to it.)
Other than that. . . still waiting for the motor mount bolt to fix itself, and tomorrow weather will be perfect to go way up on Windrock and change a track on a Morooka. Have a good week, Willie!
