Anyone had this issue...?
I bought a beat up old Bobcat 743 and it mostly worked as it should. The tilt spool forward seal had a good leak and the boom down pressure seemed off almost like the cylinders were binding up when going down and the float function didn't really work.
I decided to replace all the seals, detent balls, springs, plug & o-ring and boots. The spools were a pain to get in and out (as they had a tight fit that made it difficult).
I put it all back together now my boom only goes up regardless of what direction I push the pedal. There doesn't seem to be any tilt function either. Float works (that's how I lower the boom while I'm trying different fixes.
All of my research points to the aux being stuck on but that doesn't seem to be the culprit. I've taken the aux spool out and made sure everything looked good and it seems to go in and out of the detent freely.
It's one of the 4 valve control units
1990 743 with the Kubota
