MarkS1
Got a 2005 Bobcat 323-J that hasn't been serviced in a long time. The hydraulics leak a little, requiring about a quart or so after 5-10 hours use. My main complaint is the controls seem awfully jerky. They will respond nice and easy at first but just a little too much handle and they jump. However, it's my first time driving any kind of hydraulic equipment and I don't have much seat time, yet. I have the full shop manual and I did grease all lube points/fittings.
Here's my questions:
1. Going to swap out the hydraulic filter, today. Manual shows only one on this model, #6653336. There is no separate case drain filter I can find. Any other filters or debris screens to consider?
2. Is there an adjustment valve or knob(s) for controls response? None are mentioned in the manual.
3. The owner has been running Traveler's VG32 fluid which is not even listed as a compatible grade in the manual. Should I drain and replace with VG46? We'll be running the excavator primarily through the warmer months (+90°)
4. I cannot spot any obvious leak(s). Should I just inspect and turn a wrench on all fittings?
Any suggestions would be appreciated. Thanks!
