Majority of Engine Machine Shops insist on machining cylinder block areas that are per OEM's guidelines not a issue. Liner ledges, slightly corroded coolant transfer holes, decks. Yes, helps pay for expensive machine tools.Worked Continental Engine Rebuilders for a short time, they INSISTED on installing upper bore sleeves mainly to pay for the damned machine to do that as was seriously expensive. They had a grand time explaining away the coolant seeping nightmares they sent out, I left after a short/long three months
Short/long 3 months employment duration; large employee turn over? At least you were familiar with mechanical engine assembly. That is a constant problem with machine shops, low pay and cannot keep experienced journeyman machinist.
I put a stop to sending blocks out for repairs, typical D346 V8 over $3,500.00; equipment manager receiving a kick-back. Not broke, don't fix it.
