Hallback
CPL is 891 I believe.
a sack full of a$$holes lol never heard that one beforeTo me if the overheads were adjusted wrong it should have run like a sack full a$$ holes.
I think that cam was possibly bad when inframed.
The ones I saw done like that did not run well enough to leave the shop. They readjusted them, replaced push tubes and such. They left running fine but damage could have already been done. Regardless of the cause bad is bad.To me if the overheads were adjusted wrong it should have run like a sack full a$$ holes.
Not surprising; reflecting a bit (old memory), Stainless aftermarket ‘pulsed exhaust manifolds’ were available prior to introduction of Cummins Big II / 1979. The manifolds were developed by Calif off-road racing airflow expert, his name ? My memory won’t cooperate. Probably not over 150 stainless manifolds produced, expensive to fabricate using round 309 stainless tubing, 6 pipes into cast stainless center section that looks like Cummins cast iron pulsed manifold. All about retaining heat energy; i.e. higher exhaust gas velocity to spin up turbo quicker.Don't remember any stainless
Cummins camshafts with crowned lobes; you cannot see crowning with naked eye, crown ½ degree or less across lobes parallel to cam center line. OEM effort to reduce lobe failures after introduction of PTD-TopStop-DFF injectors, pneumatic variable timing, step timing; emissions regulations beginnings. Maybe Pumpguy has Service Bulletins, I trash canned all of that subscription literature and engine advertising brochures.I've been in been in just about every III cpl there is and I don't remember any crowned lobes on rollers or cams. Picture please.
you brought up 2 things i thought everybody had forgotten custom cal sc manifold and cam bearing tool still have one of those not diy though. custom stainless manifold i had on a400 magnum diy project. i got little over 435 out of a sc that stayed together for a162k miles that i ran it. sold the truck and then lost any further contact with the buyer so don`t know how long it lasted afterNot surprising; reflecting a bit (old memory), Stainless aftermarket ‘pulsed exhaust manifolds’ were available prior to introduction of Cummins Big II / 1979. The manifolds were developed by Calif off-road racing airflow expert, his name ? My memory won’t cooperate. Probably not over 150 stainless manifolds produced, expensive to fabricate using round 309 stainless tubing, 6 pipes into cast stainless center section that looks like Cummins cast iron pulsed manifold. All about retaining heat energy; i.e. higher exhaust gas velocity to spin up turbo quicker.
Spam, couple photos of 1962 DIY proto-type rear cam bearing removal tool. Bitch digging out rear cam bearing while in-framing without pulling trans, bellhousing.
Sad thing is, no matter how much we'd like to learn about all of this, guys like T/S, RZ, and Stan have forgotten more than we could ever possibly learn. Agree completely with the fact it's awesome reading these threads though. Thanks guys for sharing your stories.
Actually I do, showing them a touch of humility seems to stop that "I know everything" attitude. Worst guy I ever dealt with was halfway through a 2 year course at the local community college, totally wasted his tuition and had zero mechanical aptitude. But he could tell the other guys he was smarter than me because he was "Educated", too bad his education didn't teach him how to adjust a clutch or how to find problems in trailer wiring.I bet you say that to all the young mechanics
