I have heard of it done but never had it done, in the KC area there is not anyone i know of that turns pins anymore, HeavyQuip used to do it and they quite. i have a 963C i would like to have turned if i was to find someplace that could do it, what should i pay for them to be turned? and should they automatically charge for nuts and bolts? and should i have my guys take the pads off to save money?(how much)
Pj
Special
Is there something I would have done to cause excessive wear? The tracks never looked to tight or loose.
The JD salesmans says that maybe I should upgrade to a 700. I dont know how a 700 would be that much better for what I do then the 650h Thoughts?
David
I dont know what ratching means
That's called... "jumping a tooth, or, sometimes, jumping a cog".right now the right side after you go about 15-20 feet will make a clunk sound and it looks like the track gets real loose for a second. That repeats about every 15-20 feet.
I would also say that there is no way I'm ever going to stick any body parts under a dozer just being held up the the blade or ripper.
Got my hand caught between two pads when climbing down off the 15C last spring when I had the tracks spilt. Instead of just hopping off I climbed down and just as i set my tools down on the track the loose end moved over the front ideal and my hand slipped and ended up between the two pads. Even trying to be careful thing can happen VERY quickly. I had a shop foreman in North Carolina, when building stock cars that had a phrase bout thinking bout putting your hands in someplace.
Trbo
Davidco, All you need on your chains are new pins and bushings pressed into your links and new grouser pads. You don't need new track groups. This will save you around a thousand dollars. You need to replaced your sprockets. The wear on your idlers and top roller looks good. Push the blade down and tug on the bottom rollers to see if any need to be replaced. Your roller flanges are not hitting the pin bosses on your links so the height is probably o.k. Don't let the John Deere salesman sale you something you don't need. They are notorious for that in my area. Don't forget they work on commision.
Thanks, QuickTrax
QuickTrax do you know Tommy?
Yes, I know him. I guess we are talking about the same Tommy.
The Tommy that does the Under carriage appraisals.I'm Billy J.Used to drive the haul truck and lots more for Johnson Const.in Cleveland TX.
ATCO, This usually is the way we check bottom rollers. Majority of the time we are in the field looking at machines before they come to the shop. Blocks are not always available. Its not bad until they have full rockguards on the bottom. We sometimes hit them with a hammer to see which ones are loose. I paid the price when I went to tug on one on a D61PX and it was Red hot. I had roller flange burns on my four fingers for about a week. When machines get to our shop we remove the tracks and block them up first thing then evaluate the machine.
Ya, I mentioned you to Tommy and he knew exactly who you were. Small world.
