bflobil
Has anyone added an aftermarket boom suspension on their wheel loader? Is it worth the cost to install a factory system? I'm interested in all input I can get?
Thanks a bunch
Thanks a bunch
Yes, probably most commonly known as ride control
Actually there will be frequent occasions that I’ll need to road the loader from site to site instead of hauling it and I believe it will be easier on me and the loader.
Is ride control going to help with empty bucket roading? I found the cat I ran with it, it only really made a difference when loaded, not so much with empty bucket.
I will definitely have to check into the volvo set up also...but i am hoping for someone with experience in the aftermarket ride control to chime in and see how those compare to factory setups.The challenge will be accumulator displacement. Having the correct cavity to cushion the + side of the lift cylinders. Volvos system is very simple and robust and could be retrofitted to any machine with some hoses and flanges. and a simple switch and relay. It wouldn't be integrated to speed or gear selection like the factory but would function beautifully anyway. Did cat offer boom suspension on a subsequent model that perhaps used the same control valve and loader frame? That may be easier to retrofit.
I will give Paul a call and quiz him about that....thanksTry 1-800-990-7923, ask for Paul Imm @ Paul Weaver Construction equipment. Few Years ago someone in VT had it done, i have no idea on cost
