SkipBurney
Mine looked nothing like that I checked every disc and floater and they looked like I just took them out of the package. I cut open the trans filter and there was nothing in it al all
Nah, you're just getting to know your new to you backhoe. I wonder what shape the synchronizers are in? If they are in good shape you can shift gears on the move. If they are worn out you can shift gears mostly just stopped.I think I went at mine backwards
So I guess that was the original problem?I found the wires to the clutch disconnect button on the loader completely chewed in half today.
I found this on the net. Not exactly yours, but look for the port labeled PS. That is a metric thread port. I believe it's 10mm. When all is well I get approx 240 psi there.
Got my adapter in today I am gonna check it out later today it is terrible hot here. I found the PS port yesterday. I hate to think the charge pump is bad we pulled it to the shop with my Ford 5000 when I unloaded it and the parking brake wasn`t on then.
I removed the large line from the transmission to the rear end
