I unplugged the Machine ECM. With the monitor fuse removed. See pict
I then, with my test light, again checked for the drain.
The same thing happens with the test light.
If i keep the ground of the test light connected to the negative cable, then put the point of the test light on a machine ground, the light will light momentarily light then fizzle out. if i let the machine sit for a bit then do the test, the light is a bit brighter and longer but fizzles out. In neither case does the light stay on for more than a split second.
I did not disconnect the key switch as that is another process.
