benbuilder
I have a 249D. Recently, I’ve noticed the battery dead every time I go out to use the machine. When i check for continuity through the kill switch, it proves positive. So, I initially thought it was a bad Kill switch, which this machine is equipped with. I installed a new switch, same problem.
I did some testing and determined that when I connect a test light to the negative battery cable and and ground it out to the body, The test light lights up. So I know I have a draw. I have also tested with a voltmeter I have about 11.7 V that I’m reading.
I pulled every fuse and relay in the cab, and the test light did not go out .
Is there another fuse somewhere else on this machine that I could pull to see if the test light goes out then I will know where my drain is.
Or any other ideas before i bring it to CAT.
Thank you.
Thank you.
