Is that wire marked 104 on the outside by any chance.? See top LH corner of the illustration in Post #40 on the previous page. The wire going out of the fuse should be 105.
I think it is the fused power supply (the fuse is visible right at the top of your photos) that feeds the key switch and the Monitor (Page 8, Grid E-3) if you follow it through the schematic. Replacing the wire and pulling the fuse should give you the same result. If that is the case my next suggestion would be to replace the fuse and unplug the Monitor Panel then see what happens
