Shimmy1
Had a stray follow me home yesterday. Like the title says. Seems to start ok the first time, or if you shut it off without it being funky. Issue is, after about a minute or two of running, it almost seems like it is running out of fuel. Can hold the pedal full down and it doesn't do anything, eventually (after about a minute) it'll take off and run ok, then back to crap. Changed filters, both were full, but did get a sucking noise when I pulled the primary. Here are a couple pics, the return is kind of goofy, the return from the head goes to the pump, then tees and a little line crosses over to the other side, where there is a cross-looking piece where the return to tank is attached. Going to put a gauge on the supply to the main pump to check transfer pressure tomorrow.
