The injection pump has engine oil running threw it for lubing the pump so it will be oil temperature.no, the injection pump did not perform any work. is it normal that it gets very hot? the regulator part of the accelerator
Your Feb 1976 built loader is suffering with knackered pistons, to remove the oil pan is easy but to remove the sump plate you will have to lift the engine around 20 mm to make it easy, this involves removing the drive biscuit bolts on 1 side and jacking the back of the engine up, the front mount is rubber and can take a small movement or you can loosen the front mounts, no Turbo's ever fitted to 951 A, B or C Series, a good thing to also check is the engine oil cooler as it will be at least 20 % blocked, the piston damage could well be caused by pump timing wrong or poor fuel capsules, to use this much oil it would be big chunks of piston damage in the top ring area. tctractors
YesYou said it dries up but you said that you are still consuming oil I think its time to tear it down
One more longshot pull the valve cover and start the motor and check ends of rocker shaft , if the plugs are missing oil will flood top of head and go down valve stems. I've seen that before but not very often.Yes
Before disassembling a good engine I always think about it.
I wanted to understand the diagnosis first.
At full throttle the oil can burn in the combustion chamber.
It is not clear, usually there is a lot of blow by. In this case the engine is powerful and does not lose revs during the effort phase.
Usually an engine gone by a thousand other signals and I was not here asking for information from those who have much more experience than me.
Would too hot oil risk this problem?
slightly, but insignificant. I unscrewed the oil top-up cap at full throttle. It doesn't move at all, zero. What do you tell me ?You say you have no blowby at all. Not even vapors. I think the blowby tube filter is possibly plugged. You should see at least vapors
The engine oil cooler will be pegged up with debris in the water side of the cooler, the water pump sends the cooled water from the radiator bottom hose through the engine oil cooler, then into the cylinder block, earlier models had a transmission cooler also, your transmission cooler is air cooled built within the radiator section.hello ,thank you .
I did not understand the question of oil stuck at 20%.
By removing the exhaust manifold, oil flows out of all 4 cylinders.
Perhaps from the most abundant number 3. All this with a test with the crawler loader stationary.
using it, as mentioned, no loss, maybe some, but using it and driving I don't notice, with the heat it dries up and then the symptoms I described in the previous post.
