1693TA
Did notice yesterday some of the vertical tubes which comprise the basket are going to need replaced citing rust and splitting from freeze/thaw cycles. I couldn't latch the gate as the striker plate is gone from being rusted away. I'll probably just separate the expanded metal mesh from the existing tubing and replace it wholesale so the cage can be relied upon. this existing one is kinda marginal at best.
Forgot to mention in yesterday's loading post that the machine ran out of gasoline on the ramp incline of the trailer. Being that truck was my only source of transportation and I wasn't going anyplace with the manlift's steering axle just about 1/2 way up the ramp, I elected to disengage the drive hubs and winch it up. After cabling, and chaining to the tiedowns for a secure pull point, I put some slack in the driveline with the winch, removed the hub caps and flipped them around to disengage the planetary drives. Up to the point of running out of fuel, all was going well. At my shop I just grabbed my "yard horse" Mack tractor and pulled it off the trailer where it rests now. It was raining like a cow pissing on a flat rock so I went no further with it other than starting the engine. I'll lift the drive axle and engage the hubs, (by hand) this afternoon when it warms up a bit. Hopefully get a couple of small repairs prior mentioned accomplished also.
