I did and thanks. Went ahead and got cap, rotor, points, capacitor/condensor, wires, and spark plugs. I had pulled the coil and ballast resistor last evening and brought it home as didn't have a meter and couldn't "ring", or measure anything. Coil secondary is found open, and the resistor is quite corroded, so going to replace the whole shebang at once.
Complete unit holds 70 gallons hydraulic oil and there is seepage evidence under the unit. No tellings since the fluid, or filters were last changed and I don't know if there is enough oil in the system to work anything, so will take a few gallons with me in a pony tank next time.
