Sorry, i know nothing about the tranny/ torque converter setup. My old Beast is long gone
Thanks. I really would like some help. I have allot of land to clear and a tractor that does not push.
On a power shift machine the torque housing/ bell housing has oil in it which gets dumped unless the line is plugged. Has nothing to do with the transmission seals as it is a separate housing from the transmission. I have been working on International and Dresser machinery for close to thirty years.- if that helps. It may be that the starter rebuild guy is not sealing it properly. Are you losing hydraulic fluid ?? Are you gaining engine oil??
