Lets see your "ultimate" service truck!
FSERVICE
indiana
drifter
does your unit keep the cab heat on or the ac on when the truck engine is not running? also what engine is in the unit you have?
Drifter
The compressor engine will probably heat the cab. I havent tried it only becouse I am usually out in the middle of no where and if the truck wont start it could be a long walk to get cell service.
When its cold out you have to have the truck engine running for atleast a half hour to get the compressor hot enough to start.
Last time I was in getting some work done on the compressor the service guy mentioned that the had hooked them up to work the A.C.
The compressor has a 2 cylinder kubota diesel.
N.B.CONCRETE
N.B. CANADA
OWNER
No VMac unfortunately. I have on of these in the truck. http://www.airworkscompressors.com/
Cant say I am all that impressed with it. Doesnt put out as much air as a VMAC. It is really loud. Another engine to change oil and filters on. It takes up a big amount of space in the back of the truck, need air to keep from over heating which means you cant stake **** around it. The reason they went with this is to save fuel but the alternator on the compressor is to small to keep up with the crane and work lights. Did I mention it is really loud?!?!?
Thats interessting , alot of extra weight too ? Its so easy to get these things way over weight too with some parts laying in the bed .
You run any type of system off your cooling system to heat up equipment coolant for better winter starts in the bush ?
Drifter
The Sterlings GVW is like 8800 kg and I am pretty close with no parts in the back. Not good when the road bans are on.
Dont have any thing off of the trucks coolant system to heat up a frozen machine. I have a welder though. In the winter plug in the machines block heater and get the herman nelson going with a parachute. Couple hours at
-45 and a guy can pretty much get anything to start.
FSERVICE
indiana
drifterhttps://www.heavyequipmentforums.com/Forum/images/icons/icon5.gif
"get the herman nelson going" "parachute" please explain what you are doing with the parachute?
Drifter
The herman nelson is a heater and the parachute is a actual parachute. Its made of silk so it will hang over the machine or drape over the machine. Keeps the heat in. Wish I had a picture.
N.B.CONCRETE
N.B. CANADA
OWNER
I know I'm over the GVW 9026 kg constantly . I got a Miller in back for juice and apprentice welding/grinding school . Got a pair of quick disconnects on the front grill with ball valves and two length of hose , it will have a frozen machine running in less than 20 min . Some of my newer machines have ESPARs in them , so thats easy . I use a parachute to keep the snow off when I'm working in a snow storm , super easy to store and fold up .
FSERVICE
indiana
parachute??
i am in southern indiana so the parachute idea is new but is a really great idea for working in the snow (which we had plenty of this winter) i will find me one before this winter
Drifter
I like your coolant quick coupler idea thats slick. I would do that but I work for like 30 different outfits.
N.B.CONCRETE
N.B. CANADA
OWNER
That would be alot of plumbing . Things still busy out your way ? We are moving at a better pace than last year .That Chile earth quake wrecked a bunch of pulp mills down there .
N.B.CONCRETE
N.B. CANADA
OWNER
That would be alot of plumbing . Things still busy out your way ? We are moving at a better pace than last year .That Chile earth quake wrecked a bunch of pulp mills down there . Things are drying nicely and road restrictions lifted yesturday so its a good spring .
Colorado Digger
Carbondale,co
the herman nelson and parachute thing
all i know is a weed burner and a concrete blanket go a long way at -20f. all of this is so elaborate and well thought out.... leave it to the mechanics i guess.
FSERVICE
indiana
NB concrete what does you company do log trucks? concrete? construction? general contractor? looks like you have "job security" with the list of equipment there Has it warmed up any there yet?
N.B.CONCRETE
N.B. CANADA
OWNER
Logging contractors & Concrete contractors . Its warmed up some .
wildhorse trnr
Texas
Field Technician
extra cab
That's the techs office. Extra cab is nice. Place to keep manuals, all your paperwork and logs, files, etc. I used to drive a service truck with extra cab, found it so much more useful than a cramped single cab. Freedom to move around a bit. :yup
I always had singles till recently, the extra cab space really comes in handy if you work out of town much or if you have need for rain gear. Most of my essentials are stillin the front with me though.
Muffler Bearing
Colorful Colorado
Truck Mechanic
I wouldn't call it the "Ultimate", but..
This is the hand-me-down 1990 Int I get to run service calls in. The labels on all the toolbox drawers are in spanish, (so far I've figured out "impactos") the cable on the crane is nasty, the whole truck is pretty rundown after a hard life in the gravel pit. BUT! I've outfitted it with one beautiful assembly that makes it all worth it. That's a really bad photo of my custom "Drum Jumper Unit" I can pull up next to a downed mixer, hook up two pressure lines and a case drain, hit the pto on the service truck and spin 10 yards over fast enough to kill a load, or use the control valve to even off load the mud if I want to.
So far I've tested it on a load of sand, maybe I'll never have to use it, but it's nice to know I have it.
td25c
indiana
Looks like a handy rigg Muffler Bearing.I love the "drum jumper unit" thats pretty cool.How do you like the lincoln gas drive welder?
