The other day, I started dismantling the top cover. Disconnected the return line. Took off the return adapter and blew through the glass check ball valve. Seemed to be working. Went ahead and blew through the return line. It was pressurizing the tank as I had my hand over the fill. All clear there. The top cover for this DB4429-5303 pump is on with
5 point security torx. Not the typical 6 point security you get at the hardware store. Everything on pause waiting on some Taiwan bits from Bezos. BTW, while awaiting bits, I assembled the lines back up and made sure it fired up in case the bits I ordered didn't work.
Bits are in and they fit! Tonight, I didn't wiggle the throttle linkage or tap the pump. Started right up and didn't go dead on me like it has the last half dozen cold starts. It ran a little rough but it smoothed out.
Turned it off and started disassembly. Got the cover off. The metering valve seem to move freely. Everything looked relatively clean. I'm assuming the metering tab pushed all the way toward the back of the pump is off. The solenoid releases it and allows it to come forward via spring pressure.
I did see where the solenoid has a crack in it, but it was snapping like a turtle when I cycled it a few times. Don't think it's the problem, but a problem that probably needs addressing at some point? How severe is this?
I did drain the top reservoir and sprayed a bit of brake cleaner on the moving parts. I put the cover back on, hopefully correct, I had to push the MV to the back to get the cover on. Hope that's right. I didn't tighten it back down in case you guys want me to look at something else.
Here's a video of the movement of the MV. I was wondering what the function of the little folded wire was in second picture riding on the center shaft toward the back of the pump. It looks like at full stop it pushed the big cam thing over. Not sure the purpose of this.
