Had one other issue chewing on my brain, obvious when pulled head that 1/5&6 did not ever fire in any of the run time I put on this. NO carbon in upper sleeve regions just oil. So got to digging thru harness and connections and wiring diagrams. NOT certain if is missed Common Ground on Single Plug 6NZ harness or just corrosion or possibly bad connections in existing Two Head harness, does not matter. Just ordered 6NZ style Single plug Engine side and under cover harnesses, less than $600 and NEW, in stock. should be here sometime LONG before engine is back in frame. Eliminates above questionable issues where will only have to blank off Rear Lower Base Valve Cover harness port. P/Ns 202-1060 ECM side, 425-6526 in cover side. Covers needs of Sensors, Injectors and Engine Brake as Only needs, may need to change out SOME sensor plug styles, maybe not.
