Takeuchi TL26 questions
Incline
California
Tool king, much appreciated. The manuals have been downloaded and am eagerly reading now.
Best Regards,
Incline
RGA
Glasgow
Hello everyone, I am new at this forum. I've got failed hydraulic pump on Takeuchi TL26. Does anyone know is it still possible to find a replacement pump anywhere nowadays? Used or reconditioned - any option could be considered. I tried to search online but nothing really comes up. Thank you in advance
chrisw21_2000
hartwell ga
If you pull the pump apart, you can see if the damage is bad enough not to repair it. I faced off the internal parts and reassembled and have been using for years
The Real Sasquatch
South Eastern Ma.
Hello, I found this forum while google searching TL 26 issues. So I'm brand new here. I am looking at a 4000 hour TL26-2 that is still being used by a smaller owner operated excavation company. He said that there is a leak at one of the joysticks. Its small and he has just been topping off the fluid every couple months. If I end up purchasing it, I would like to fix it. Is it a big deal and has anybody here had it happen? Also what else should I look for as far as known areas that may show abuse ,etc.
I plan on using it around my house and shop. Plowing my driveway and parking lot. And also to build and maintain some trails, and my property. Its a small 5.32 acre slice of heaven. I think that if its in good shape, it should do what I want. Also as my name may suggest, I am on the bigger side. 6'9" and around 275-300 pounds depending on what I ate. How is the legroom in the cab? I've heard that this brand has larger cabs. I used to work for a developer in the early 2000's. For about 10 years. I ran a case 1845c,case XT75 and then a Cat 236 skid steer, spent most of my time in a cat 320 excavator.
Recently I was running a Komatsu CTL and the na Deere 333G. That Deere is so strong!! I know the TL26 will be closer to the older machines I ran. Back then I also maintained and did some of the easier repairs when machines were not inside the warranty. I now own my own business, Vehicle lettering and powersports graphics/parts/gear. So I would not use it very heavily. Maybe pallets of firewood, or parts orders here and there. Snow ,yard work and trail building. Maybe work it a few hours a day here and there. And a full day or 2 here and there. But also sit for weeks. Sorry for the long post, Thank You to everybody who has posted info on this machine so far. It sounds like a solid machine.
