...doesn't appear to bog down when the fluid hit the pumps...
Has it been cranking fine for a bit until the "fluid hits the pumps", and then bogging down?
With the other starters, yes ,this one seemed to want to pull through, its about the same starter that is on my 92 ih 7.3 diesel ,just with an adapter )but since it's been down to 2 deg f last handful of nights and hasn't got above 30, I wanted to wait a few days for warmer weather to really try to fire it, heck even my Volvo's have been a bit cranky in this weather. Best to wait for better conditions for a proper test fireHas it been cranking fine for a bit until the "fluid hits the pumps", and then bogging down?
Should be a bypass terminal on the starter solenoid to feed the ignition coil with, straight off the battery until the starter kicks out.....
Rldsl,
I just sent an e-mail to Contractors Crane in Houston on your behalf. They'll likely have your starter and be able to troubleshoot your problem (they even had one of their mechanics call me when I was replacing the rubber support pads between the rear axle and frame.....those were a bitch). I purposely bought everything from them (all OEM or better) for the quality parts and help.....so as to not have to "rinse and repeat" as your going through now, it's frustrating....as none of this stuff is light (I think the starter is around 50 Lbs).
You are correct, but I had earlier found the factory wiring going to and from the dash extremely corroded with with high resistance so, at least for now, it's a lot better off with its own circuits, until I have a chance to completely re- wire it from scratch with all new materials, but for now.... I'm beat .3 months of that beast kicking my hind end, it's time for a vacationNow that you have it starting good I'd reconnect, at least temporarily to the main battery system to see if there is any problem with voltage drop, if it spins over that good I don't think you will have a problem. I just hate extra non-essential electrical components and wiring.
