That should be the one. It may be a newer VB, than the one pictured in the manual I have. My guess, would be to back off the outer jam nut, while holding a screwdriver, in the slot, then take the cap off of the valve. if you see a spring, under the cap. and not just threads and another jam nut, just put the cap back on, and do the adjustment as I wrote above. If there is no spring and just threads and another jam nut, underneath the cap, then use the nut underneath the cap, as the jam nut. The nut that is on the one in your last picture may just function, to lock the cover on, sometimes things are changed, on a 60+ year old machine...
