Turbotexas
Does it show where this relief pressure valve is? I'd like to go through it and clean it and insure it's working properly!
I believe it on the valve bank, somewhere, I'll check the manual, again...Does it show where this relief pressure valve is? I'd like to go through it and clean it and insure it's working properly!
I just bought this two weeks ago! Once I get everything up to par, I'm hoping to be able to pick up some extra work doing road work! Just build a small ranch roads and driveways etc.Your D looks like it's in nice clean shape, do you do dirt work with it or road maintenance with it?
Well the reason i asked was that with some new sharp bar lug tires on it that lil darling will move some dirt if you get it off road, if you are only maintaining gravel roads, I'd prolly save my $$ and get some new hoses like d9gdon mentioned.I just bought this two weeks ago! Once I get everything up to par, I'm hoping to be able to pick up some extra work doing road work! Just build a small ranch roads and driveways etc.
my neighbor has some new military tires in a 900x20" size! They're a little taller than the 8.25x20's that are on here?Well the reason i asked was that with some new sharp bar lug tires on it that lil darling will move some dirt if you get it off road, if you are only maintaining gravel roads, I'd prolly save my $$ and get some new hoses like d9gdon mentioned.
I was hoping to trade off these tires for the work on his drive? Thus no outbof pocket expense? But if the 900x20 is too tall, then I will either ask him to get something else or just find the one I need to make aIf you are going to spend some $$ on tires, get a price on some bar lugs, Specialty Tires of America makes them from the old Goodyear(I think) molds. These tires will bite well enough that you will wish for more umph in the motor department. It will also make it easier to steer in a tight circle as the front end won't plow nearly as badly.
can you show me some photos?If you are going to spend some $$ on tires, get a price on some bar lugs, Specialty Tires of America makes them from the old Goodyear(I think) molds. These tires will bite well enough that you will wish for more umph in the motor department. It will also make it easier to steer in a tight circle as the front end won't plow nearly as badly.
OK, Finally got back to the manual re hydraulic relief setting. First, you are looking in the wrong spot, for the RV. It is on the rear left side of the valve bank, sticks out horizontally.
Next, check the pump drive to make sure belts are tight, not slipping. install a tee fitting, and a 2500 psi hyd gauge into the pressure line, from the pump to the VB. Next, start the machine, get it up to operating temperature.
Drop the blade to the ground, then apply downward force on one of the blade cylinders, the gauge should read 900 lbs. If not, loosen the jam nut, on the RV, and the acorn cap, that covers up the screw head. To increase pressure, tighten the screw, to decrease pressure, loosen the screw. If you screw the screw in, and pressure doesn't increase much, or any, your pump is weak or the belts are slipping. Manual don't say a thing about what RPM the test should be done at, so I'd say, try middle throttle setting. If it won't put out 900 PSI at high throttle, then your pump is prolly bad... Good luck.
TT, seriously, see what Gensco has, they had great prices (I thought), when I put 'em on, about 10 years ago. Gensco is the tire company that advertises in farm magazines, for used multi-ply aircraft tires... If I can find a link, I'll post it, later...
On edit, googled gensco, still doing business, but their site don't show used military tires, any more, you might want to email them, though...
Here's a link to M. E. Miller's site, they DO have 7.50X20 military, but the rears will set you back $ome...
http://www.millertire.com/categories/truck-tires/?sort=featured&page=3
