I know the afternoon I was watching them work, in the muddy parts of the job the moisture content was running 18-25%, those tractors would just keep going. I remember thinking that they were making as good or better time than the 627's I run could, as I'd have been in second gear at full throttle for minutes on end just to wade through the stuff.
The crawlers don't waste time waiting for a push cat, or pump loading just to get a half load on, and then have to wade to the fill to get rid of it again.
How they make money on a longer haul, or in good material, I don't know.
They make their own haul roads, so no expense using a grader there.
The cat/can combos didn't tear the job up as bad as rubber tired units would have, which is important in Nebraska in the summer, as rain can come along with short warning.
They had a large disc and several compactors processing the fill, laid down in thin lifts and covering a large surface area. They were loading dryer soil in these pics, to mix the fill. Something you have to do a lot in this area.
You frequently have to make several fills on jobs around here, lay a wet pass down and then move away for a day or so while the material is disked to dry it out. Either that or haul from different cuts to blend wet and dry dirt together.
Still not sure how they make money with undercarriage costs what they are.
alan627b
