This is a very difficult question to answer without being able to demonstrate the techniques I would recommend. In my opinion there are too many things to list (if listed in detail) that seperate the men from the boys. If your operators are competetive in nature, concerened with getting maximum efficiency without sacrificing machine life or job site safety, and can be depended on to give you an honest days work for an honest days pay, than I think this is a winning combination. These types of employees will figure out how to be productive in whatever situation you stick them in. If you have this type of employee I would like to hire them. I find it harder and harder to find good employees. In the video, that was offered in a previous post, I can find many things that that operator is doing that are wasting time and efficiency. If I had to offer a few tips it would be these:
1) The angle of the teeth will always be adjusted to suit the resistance that the dirt is giving (which usually varies along the trench bottom). As a general rule the tips of the teeth will be the leading edge so the angle will be fairly aggressive. The steeper the angle the better the penetration (to a point). DO NOT over rotate the bucket. This will only make the machine work harder (the heel of the bucket is not very sharp so it tales a lot of energy to try to drive it through the dirt), and accomplishes nothing except wear out the heel of the bucket, waste time, and fuel. The digging cycle is the blending of crowd, curl, and boom to fill the bucket in a manner that does not "force" the bucket through the dirt. A good analogy (from the "nail bangers" hand book) is to let the tool do the work. If you are using a lot of crowd force to make the bucket go through the dirt than you are not using the correct technique. This is not a huge problem in the middle of a field, but it will lead to broken obstructions, if you encounter them, and irregular grade at the trench bottom. A good operator can feel how hard the machine should be working, and blending all the functions to keep it in the "sweet spot" is part of the art of digging.
2) Do not over fill the bucket. The bucket should be brought to the spoil pile as soon as it is filled. Many operators will continue to crowd even after the bucket is full (out of habit I guess). On an excavator, the bucket should be filled just about the point at which the operator must boom down to continue to fill the bucket. Once the boom begins to go down (on the bucket fill cycle) you are losing efficiency.
3) When exiting the trench the crowd should be moving out at the same time as the boom is coming up. Crowd out will continue until the bucket has been extended all the way to the beginning of the cut. When I begin my upward cycle I will begin with boom up priority, and then blend to crowd out priority. If the material is sticky or does not evacuate the bucket fast enough, I will give the crowd a "jerk" to help persuade the dirt to leave the bucket. As I begin the return cycle the swing has priority, and I will blend to crowd out, and then boom down priority. When done correctly the casual observer will see one fluid motion. Many times you will see the operator move the crowd back towards the machine (when returning to the trench after dumping) just to extend it back out once they are over the trench. This is a wasted motion. This can be (for many) a hard habit to break. It takes patience and discipline to get the correct motion down. Crowding out while booming down can be used to take energy away from the swing and transfer it into a downward motion. It can make the transition smoother. In time a good operator will modulate his controls to make all his transitions smooth (in the manor I just described).
5) Different circumstances will require different techniques. Digging in rock is different than digging in loam. Digging in a field will be different than digging in the street. I'm sure you get the picture.
If the operator is working at maximum efficiency (correct digging angles, and proper techniques) the tractor will not be over worked.
When I am digging I usually don't think much about technique anymore. I don't think about what my hands are doing. My machine has become an extension of myself, so my thoughts are only to what I want the machine to do. This frees up my mind to think ahead and think about specific job circumstances and possible obstructions or issues that may need to be addressed. The exception to this is if I have to run a machine that I am not familiar with, or that employs a pattern that I am not accustomed to (BTW, CAT controls rule!).
After a while it all just comes naturally.
BTW, I am very competitive. I have learned to use this to my advantage. I want to be the best operator (or whatever I am doing) I can be. This means more than just being fast. It means digging the most, best, and safest trench while not breaking anything. I want to be the best employee (though I am now self employed), or, as is the case now, the best contractor/vendor, I can be. This competitive nature is what makes capitolism survive, and it probably can be argued that it boils down to a basic instinct that Darwin had a theory on.
If only I could spell.
