I never minded overhauling the two stroke engines, just were a little too fussy as to fitting sleeves. I wore two Sunnen hones out fitting liners in the 71's. Many except us old farts would forget to replace the 'pencils' at the water pump and generally another somewhere hidden in plain sight point where the blocks would get thinned out from erosion and corrosion, conversion to water filters helped much of that. The 92's I worked on were usually the complaints, not enough power meaning they did not turn tight enough even as they would pull hard, not enough noise as the turbos on those and the old 350 71's would quiet them down. A lot of people failed to check wrist pin seals adequately where a few I saw ran flat away eating engine oil, I argued often when what thought they were techs failed to torque the head studs prior to setting the heads. The old Maxidyne and Thermodyne Bulldogs were some tight long lived monsters as well, saw many make 500,000+ on original parts, just knocked to beat hell from piston slap.
Oh and when Harley went to belt drives or the earlier sealed o-ring link chains they no longer needed the 'programmed' leak to lube those chains. Better gaskets, seals and sealants did help in those older engines too. Loved Panheads, shovels and knuckles not so much.
