Gentlemen:
I came into this forum as a newbie with the idea in my head that I needed to buy either a D9G or H because they were big, they had 4-barrel rippers and they were well within my budget. Man, did I get a wonderful education. I thought I knew some basics about tractors - hah! Turns out I didn't know diddly-squat compared to most of you. I am grateful and honored that you shared your ideas, your opinions and your knowledge. So what am I going to do?
One member mentioned in private that if he were me, he'd rent a CAT for a week, doze and scrape around the property to see what works and doesn't work in my soil conditions. Moreover, he suggested I put the machine to good use and stockpile some material to be processed while I decide which machine would be best to purchase. I will try to rent a older D8 (if that's possible) with a three-shank ripper bar with three tines. If it does the work like a piece of cake, then I can consider down-sizing or upsizing, depending on the results.
It was also suggested I check out a few used tractors. I have started to do that and already, can start to pick-out the wheat from the chaff. I've been a bit reluctant to contact the local CAT dealer until I have a couple more weeks of looking around under my belt. Not-with-standing, I'll give 'er a go and expect great results from the effort. Always gotta think positive.
Wow. I learned about black fuel. I learned that the older D9s are thirsty critters that are prone to suck a man's wallet right out of his pants. We have a few legal bordellos here in Nevada with charming ladies that will do the same thing! I found out that older D9s were not exactly celebrated for their propensity to rip. Seems the apparatus sometimes liked to snap the bolts off the back or crack the rear axle housing. I learned a new mining terminology from Scrub Puller in Australia called "scrape and beep" which is to take just a few inches off the ground at a time (scrape) and then run over it with a metal detector (beep) to check for gold.
I know that in California, those poor buggers have had to contend with the EPA, the Air Quality Board and flaming environmentalists that are more numerous than rattlesnakes in Texas. In Nevada? Well, Nevada is and has always been "miner friendly." If the property was in a populous county such as Clark County in the south (Las Vegas) or Washoe County in the north (Reno-Sparks), then emissions would be of concern. I'm so far out that the antelope gather by the roadside once a week to play a game of pinocle to see if a car will drive by. None-the-less, that was an excellent caution that I will not ignore. Thank you, StanRUS.
Nige, you called it like it is. No doubt I'm not the only forum member who has grown wiser from your excellent advice. Damn the EPA. Nige says I want to buy a tractor that pre-dates the new computer-controlled models. Works for me! CDUB, Jonas, Lantraxco, mht1156, Clintm and Delmer, thank you all for your good advice and counsel. I've written it all down behind my ear in the memory banks and I'll put it to good use. I'll be back from time to time to ask more dumb questions and get additional direction on which way to go. Meanwhile, I'll close for now and ask one final question on this particular thread:
So how'd you guys like the debate?
Kindest Regards,
Jim Mitchell
