Steve.ahlgren85
Maybe I am wrong about this but, are any engine long block applications actually test run before they are shipped out?
My apologies. You are correct - long blocks are not generally test-run before shipping. I missed your post further above the one I was quoting from that said it was a long block, I just focused on the fact that it would be missing an oil pump, pan, etc....Maybe I am wrong about this but, are any engine long block applications actually test run before they are shipped out?
Wow,my head is spinning with all this information. Didn't realize there are so many variations to that engine. I don't know what I am going to do. Everyone here says that it is not worth rebuilding, too much to replace, clean up, too much time to spend on it. Rebuild from Capital Reman in Denver said that they can build an engine for me to the exact specifications of my serial number and arrangement number shipped to my door for $9,200.It would be a rebuild engine with new parts, reusing my oil pan,oil pump and value cover. I really appreciate all of your responses, but would like a little more advice on this option.
I'll be honest I wouldn't personally install an engine that hadn't at least been test-run on the floor first, UNLESS I'd rebuilt it myself, because then if there was any problem it would be on my head.
Can anyone help me, give me some advice on how to clean the turbo of contamination from the oil particles, or
Well, I've overhauled a couple turbos and well, they're easy as pie!! spin off the compresor wheel, pull the housings apart, clean it all squeaky clean, toss in new journal and thrust bearings and zip it all back together. Even the VGT turbos are pretty easy, remember to index everything so you get it clocked right.
