I see you have the same issue with dyslexia as me .... the correct arrangement is 4N7365 ...D6c serial number 10k10536
Engine serial number 3n24054 arrangement number 4n7635
I did the list of differences to convert 8N-4559 Arrangement to 4N-7365 Arrangement and it's so long it would make your head spin ... it's actually simpler to say what parts are common and the list is very short.
Basically the cylinder block, crank, rods/pistons, cylinder head, flywheel housing, oil pan, engine & trans oil coolers, gear group, inlet/exhaust manifolds, & turbo just for starters....
Take heart though - the engine oil pump is the same ...!
In answer to OM's question above. No, the oil pans are not the same ....
Edit: I checked SIS and 66D04353 is listed as a "3306 Industrial Engine", and the 8N-4559 Arrangement Number also ties in with the Serial Number.
