Any luck on the update for regulators?
No - i haven't heard back from anyone on this - would greatly appreciuate if someone could get us the info..
The pumps are not the same between the two models. They operator on the same principles. If you think you have a regulator issue, then stall the left track, and see if the engine bogs hard and dies or not. Repeat for the right track.
I would start with your fuel system first. Change your fuel filters, and change your air filters. Check for bad fuel lines. If they are badly cracked replace them. There is a banjo fitting on top of the injection pump with a orifice. (on the governor housing). If that gets plugged you will have low engine power.
Hey Travelling Tec,Glad that you took a fuel pressure reading. At least that should eliminate questions about supply of fuel. If you have changed the turbo boost sensor, we can assume that the engine is getting proper boost and proper supply of fuel. That only leaves the VP44 relay that could cause this problem and not put up an electrical problem on the dash. As I have stated that VP44 relay can do strange things. It has fooled man;y people into thinking that the engine was bogging but it sounds more like a steady miss under load. If you're satisfied that the problem is not in the relay, then we will have to go back to the pump regulators. Those switches and solenoids in the pump compartment, the 6 bank solenoid package has nothing to do with pump control (power lift, free swing, etc). On the hydraulic pump inself, there are 2 pressure solenoids on the tank side plus the pump proportional solenoid and the back of the pump, counter weight side. You could take that 2 wire connector apart and try the machine alt;hough as I have already stated when you run in L mode there is no current to the solenoid to upstroke the pump.After eliminating all these possibilities, we should now turn our attention to the update for the pump regulators which keep it from over stroking. I will email you the procedure and if you feel comfortable with the description, the parts are worth about $150
I was reading posts form several years back and i have the same problems with my cx210. the machine runs great for about 25 - 30 minutes and then it starts acting like its running out of fuel. The engine stumbles, it blows blue smoke and really struggles to work eventually it will die and wont restart. we found an inline filter that was pretty dirty near the tank and i changed the canister filter/separator on the rear of the machine and it did start up and run again for 20 minutes but then lost power. Usually we have to wait overnight for a restart. I know nothing about the VP24 relay or the update you spoke of in earlier posts. can you steer me thru some help?
