'68, I need rear tires on my CK. What did you go with and do you like them? Did you have to do any work to the wheels? My valve holes are rusty - I know, sounds like a personal problem.
Grady.......Yep, my rear wheels were rusted out around the valve stem hole on each side, and I had to do some "creative" repairs. After patching the rusted valve stem areas with fiberglass and bondo repair gunk, I sanded everything down/wire brushed it and used a oil primer on the rims. I drilled new holes for the new tube valve stems, but learned that you have to be pretty darn precise where you make the new holes, or there will not be room to get the rim of the new valve stem seated on the rim.........I got a call from the tire place, and had to go get the rims and grind off a wee-bit so that the valve would seat and not bind against the curved part of the rim.
Only bad thing is that they convinced me that I did not need tubes in the rear tires, and that they would never leak......but both tires are leaking and I have to keep blocks under the tractor so the tires dont go pancake flat.
Here is what the patch work looked like where the valve stem area had rusted out:
With rustoleum primer on the rims, and you can see the valve stem hole drilled out:
Here you can see where I had to grind off some metal on the rim surface so the valve stem would have room to seat:
I went with regular tractor tires instead of the original type that had the flat portion of tread to make riding on roads smoother. The manual said that I could have gone with a taller tire (so the backhoe base would be a bit higher off the ground), but I decided to go with the same size......glad I did, as I later discovered that the taller tires would not have fit. These new tires really bite into the ground when I travel over the fields.....a good and bad thing.
