driveshed
Thanks for the info, I am useing 2 " SM and 6 mil poly under the slab, the heating system is a central boiler duel fuel outdoor furance. you are right a office is a must.
Inside my building I took a 265 gallon tank,,, cut it so a back and a bottom were left,,, the bottom is about 6 inchs high to hold a lot of oil... then a screen and then to a two inch pipe to the 300 gallon underground tank with a three inch stand pipe. On the back of the cut 265gal tank I welded a screen rack to place oil filters to drain... now all I have to do is train the help to throw the drained filters out... seems to end up being in my job description all the time.Gramps how do you get oil to outside tank and when you want to pump out of outside tank how do you get it out? My father was going to put a little like maybe 5 gallon air tank in his shop for waste oil and then be able to just hook up air and blow it outside to bigger tank had thought I might do the same! Jerry
I was told to tape all joints, I ask my designer about 2 layers and he said he wouldn't do that because if your useing a vapor barrier that will stop moisture from getting in.
Hold your heat tubes as high in the slab as you can. Testing has shown that to be the most efficient. Also I would recommend thicker insulation. We go with 2 layers of 2" with staggered joints. If going less I would still recommend thinner sheets with staggered joints. Saves a lot of joint heat loss with better seal.
So what would some of you say if the cement guy says "I won't put foam under the floor. Doesn't help and if oil or the like seeps through it's going to dissolve the foam." I am certain I will be putting the foam down. Just curious what you're responses would be.
I would put a membrane on top of the insulation and then put in control joints in to control the shrink cracks. Any good floor heating pipe should have no problem with normal shrink cracking. Use a good square mesh reinforcing as a minimum and add #4 rebar dowels across the control joints, every two foot on spacing and about two ft long should be fine. Any oil penetration should be minimal. Don't let the concrete contractor place the mix to wet. Keep the slump reasonable for less shrinkage. If you get a bigger crack over time caulk it with one of the caulks suitable for sidewalk construction joints.
Edit, I would be interested in where the concrete comtractor got his information came from in which he "learned" that insulation does not help. There are many scientifically documented tests with the various applications and every one shows the pipes in the top third of the slab with insulation under to be the most efficient in poured concrete. The only one better is insulated flooring with the 1-1/4 inch thick flooring grooved for the heat tubes and then aluminum stamped into the grooves. Great for a home but not practical for a shop.
Edge of slab insulation is critical. Why not down 4' with 4" and out 4' with 2"?
Everybody uses spray foam to tighten up old buildings for good reason, but if you have interior sheeting you get a lot more r value for your money with cellulose or fiberglass.
