that block froze solid, thats where the crack in the water jacket came from, might not be the last crack you have to deal with...
I hope so. Gotta roll with the punches.
what are you gona braze it with or are you gona weld it up?
if you have any old cast laying around crack it and try the ss rod on it to see how it works, then go for the block repair..
I have had very good luck tig welding cast with 309 stainless rod
it should be fine any of the stainless rods on cast will have the same effect...just go slow , like an inch at a time and dont heat up the area , let it cool between each inch..just make sure the area is clean of any oil or antifreeze, wipe with acetone before welding, cleaner the better with tig..The only rods I have are 316 rods... think this will work?
How long do you suggest between welds?
I'm no expert but Ive heard you should hit the weld with a needle scaler before it cools
so, no pre heating, am I correct?
