bowen
I bet several folks have this problem.
I finally found the fuel leak by cleaning the injector pump.
It leaking underneath the throttle lever right there on the top right of the photo.
But when I go to the case parts there is no seals etc available. Seems I have to buy a reman unit ($1100) just for a small leak.
I found a manual on the injector although it's not the exact one, and shows no seal/rebuild kits etc part numbers.
It looks like the cover has to come off as the stem seal is underneath the cover.
This means I need the gasket for the cover plus whatever seals.
Has anyone found these parts available?
Mine is a CAV (Lucas) U3042F152. S/N 25250417
Also A50L800-1-2400 on the unit which I believe settings used.
I think the current Case # is J908645 or JR915882
