1997 international 4900
89.ho.ss
Yes I had power at the relays but the grounds were flickering. I had tried shaping relays to see if it made a difference but it didn't. Unless both relays are bad but the grounds at the relays were flickering
mekanik
The IDM relay looks to be grounded through the ECM pin 33.
The diagram does not show where the ground for the ECM power relay is connected.
Probably a body ground somewhere.
It might be an idea to make up a new ground connection for it.
Make sure you ground the correct relay.
Terry
mekanik
When the ECM relay clicks on and off the ECM powers on and off so
the IDM ground supplied by the ECM will go on and off or flicker I suspect.
Try grounding pin 5 on the ECM relay.
89.ho.ss
Pulled the ecm relay one had a solid power and three grounds solid with the key on and the relay pulled
89.ho.ss
Ok first off I was checking the ecm plugs backwards what I thought was pin 41 was actually pin 1 so with that said pin 57 and pin 1 only have 6.68 Volta with the key on. With the key off pin 1 has only 9.3 volts. Battery's have 12.5
89.ho.ss
Ok at pin 1 if I put my test light into it and test for power there is only a couple volts. If I run a jumper wire to the test light from the power. To give pin one full voltage it has no more clicking on the relays and when I tried to turn it over it was actually trying to start
