ZF Transmissions and Axles
ZFOverhaul
Kansas City
We can provide rebuilt/exchange transmissions for the Volvo A35D and A40D Machines. Give me a call at 816-650-3161 and I can give you a quote or help you with troubleshooting issues. As far as the CAT transmissions, we would have to rebuild your unit. Let me know if I can help.
Thanks,
Kyle
oldseabee
Milner, Ga.
Retired
I worked for Bell Equipment North America (Bell factory and head office was in South Africa) for 9 years in Product support. Bell Articulated trucks used ZF transmissions in several models.
JDLoader
Kalamazoo
Hi ZFPtrans. I was hoping you could help. I just left my Volvo dealer and they had indicated that ZF supplies most the axles for Volvo heavy construction equipment. Can you confirm? This would include articulated dumps, wheel loaders, backhoe loaders and others. I thought Volvo manufactured their own axles. I also thought I heard they had a partnership with Komatsu for axles, but haven't been able to confirm that. I was also wondering if farm_boy correct on the John Deere wheel loaders ZF is only under the 444J's, 844J, 444K and 844K?Thanks,
Hello members of Heavy Equipment Forums, my name is Nick, and I work for a company Called ZF Precision Transmission. We are an authorized distributor for ZF. I have listed several manufacturers who run our product. If you ever need help troubleshooting any problems with your equipment, please feel free to email me - Nick@precisiontrans.com or call me @ (215) 822-8300. I am here to answer any questions you may have. We provide 24/7 Service and Parts. We also overhaul every transmission, Dyno-Test, and back with a One Year Warranty. Reman exchanges are available. I hope the information below will help you
N. MacFarland
Account Manager
Case Wheel Loaders run both ZF Transmission and Axle: 521D ,621, 621B, 621C, 621D, 721, 721B, 721C, 821, 821B, 821C, 921, 921B, 921C
Hyundai Wheel Loaders run ZF Transmission: HL740, HL757, HL760, HL770, HL780
JCB Wheel Loaders run Zf Transmission: J 321, J 411, J 412, J414, J 426, J 436, J 446, J 456, J 712, J 714, J 718, J 722
JLG -SkyTrak - Lull - and CAT Run ZF Transmission and Axle: 644, 844, 944, 1044, 8042, 10042, 10054, 4266, 4270, 4288, 4290, 6036, 6042, 6036, 6042
John Deere Backhoes run both ZF Transmission and Axle: 210LE 310E, 310G, 410E, 710E, 710G
John Deere Wheel Loaders run both ZF Transmission and Axle: 444J, 444H, 544E, 544G, 544H, 544J, 624E, 624G, 624H, 624J, 644E, 644G, 644 H, 644 J, 744J, 744H
Terex Articulated Dump Trucks run both ZF Transmission and Axle: 2366, 2566, 2566B, 2566C, 2766, 2766B, 2766C, TA25, TA27, 3066, 3066C, TA30, TA35, TA40, 4066, 4066B, 4066C
Moxy runs ZF Transmission and Axle: 6225, 6227, MT30, MT30S, MT26, MT31, MT40, MT40B
Many more models and manufacturers can be found on our website www.precisiontrans.com
Top Dog
Central, Arkansas
Rock Quarry Owner
ZFPTrans or ZFOverhaul
I have a Case 921B loader, it is shifting hard from forward to reverse. Is there a accumulator or something that I could check?
mamuka
georgia
Dear sir.
i am looking for ZF geabox(transmision) for case 721 B 1998-year use one.
let me know ASAP please.
K.R.
Mamuka
Ermias
Ethiopia
When i disassembled a ZF rear axle of wheel loader i found out that two clutch plates are putted together side by side,no clutch disc in the middle. both have taken heat due to friction.
is there anyone who saw similar kind of assemblies? Why is that
oh also the service manual and the part manual assembles the clutch pack the same as....
Plate-Disc-plate-Disc-Plate-Disc-plate-plate-Disc-plate-disc-plate
Tony Wells
Tyler, TX
HogZilla Keeper
Lazarus thread here.....I need a current contact for this company if some rep is still a member. Need a rebuild quote on a 4WG-150
Also need to know if a transmission from a 544G would bolt up to a 544E. I understand they are easier to come by if I go for a used unit. Don't like the idea, but customer is always right, right?
Vetech63
Oklahoma
Contact Centranz in Butler, MO.
Tony Wells
Tyler, TX
HogZilla Keeper
Vetech, already have a quote on rebuilding my trans from them, but thank you. Guess they could tell me about interchangeability as well. I'll shoot them an email.
Tony Wells
Tyler, TX
HogZilla Keeper
OK, for the record, my research and consultations have led me to the conclusion that the E series and G series machines are not compatible enough to make a swap in transmissions practical. Probably could be done, but time and money, plus ending up with less machine make it inadvisable.
illy
Down on Earth
Service technician
Hello,
Hyundai HL757TM-9A has a ZF transmission but does it also have ZF axels?
Which ZF axel is the rear one? Searching for parts...
Machine S/N: HHKHLM05CF0000083
